It is currently Wed Jul 23, 2025 6:29 pm
PostPosted: Sun May 27, 2012 4:20 pm
Hi guys,
My clutch has to go about 1cm from the floor before it engages..
is there away that will give me more height?? Its nearly on and off.
PostPosted: Sun May 27, 2012 4:35 pm
Remove the return spring, then set the little stop screw to have .010" clearance at the clutch arm. Refit spring.
If still no good you probably have wear in the linkage system. Or a 0.70" MC, not a proper 0.75" one (these move more fluid).
PostPosted: Sun May 27, 2012 7:52 pm
Thanks Doc, adjusted it! Checked the Celvis pins and the pedal has about 3mm of play from rest, to when the master cylinder has any movement... so going to replace them all. The one on the arm as a 1mm or so. so I guess it all ads up.
Now off to google what size celvis pins they should be!
