Chrome plating an inlet manifold?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=7691
Page 1 of 3
Author:  Matt68 [ Tue May 31, 2005 1:08 pm ]
Post subject:  Chrome plating an inlet manifold?
Hi Guys,
I just got my new inlet manifold (for twin 1.25" SUs) from Maniflow in the UK!
I'm sending my rocker cover away to the electroplaters to be chromed, and thought i may get em to do the inlet manifold too.
Is there anything bad about getting this done? Does it bugger up flow?
Matt
Author:  simon k [ Tue May 31, 2005 1:10 pm ]
can you actually chrome alloy? I polished mine on the bench grinder wire brush and it's lovely and shiny
Author:  Matt68 [ Tue May 31, 2005 1:17 pm ]
This one is made from mild steel. I have some pics but have never posted pics, if you want i can email em to ya.
I just thought that it might do funny things to the air/fuel mix having a really smooth port. But i could be crazy?
Matt
Author:  simon k [ Tue May 31, 2005 1:22 pm ]
Matt
never seen a steel one - there you go..... I'm sure the electroplaters could block the port holes so the treatment only goes on the outside, but polishing ports and the manifold is a common performance enhancement - reduce the surface friction through the airway so the mixture doesn't slow down at the edges. I doubt if it'd cause noticable performance loss, but block them up anyway
Author:  EST-071 [ Tue May 31, 2005 1:22 pm ]
They don't chrome in side, only the out side.
Author:  simon k [ Tue May 31, 2005 1:25 pm ]
the whole thing is immersed in liquid, all surfaces get coated unless they're covered, in this case, they'd put something in the holes to stop the liquid getting in
Author:  Matt68 [ Tue May 31, 2005 1:34 pm ]
Thanks, It might just go with the rocker cover to the electroplaters' then! :D :D
It's gonna be a new addiction, I can tell now....
Author:  simon k [ Tue May 31, 2005 1:37 pm ]
I think you can buy your own nickel plating kit for about $160, chroming kits are a bit more, but why stop there, start gold plating it ;)
Author:  fuzzy-hair-man [ Tue May 31, 2005 1:38 pm ]
From what I remember chroming your inlet manifold is actually discussed as a performance type mod not just for bling
The shiny reflective surface reflects heat away from the manifold keeping the inlet charge cool so you get more air and fuel in the piston.
don't know how much difference it makes but anyway...
Author:  Lillee [ Tue May 31, 2005 1:54 pm ]
Vizard says in a highly moded engine it can give you up to 4-5hp or something like that if you chrome plate the inlet manifold becuase of heat reflection.
You can do it the cheap way which is to use elbow grease and polish it by hand then machine polish it. But if you are going to do the rocker cover then by all means...
Author:  Matt68 [ Tue May 31, 2005 2:01 pm ]
I don't mind a bit of elbow grease to polish things up, but it IS mild steel, and a bit of surface rust over my freshly polished manifold would annoy me... :wink:
I know, put a coat of clear lacquer on it :roll:
But I just like chrome.... man is it shiny.... (dazzled look as he gazes into the shine....)
:lol: :lol:
Author:  Lillee [ Tue May 31, 2005 2:26 pm ]
lol mine is alloy or aluminium of some sort, not steel so polish will stay good...
Author:  Mini Mad [ Tue May 31, 2005 3:45 pm ]
cant' chrome a redline 3005 can you?..what are they made out of? cast alloy?
Author:  gafmo [ Tue May 31, 2005 5:15 pm ]
:cry: I forgot I'll have to Bling a Manifold :twisted:
Author:  kazjim [ Tue May 31, 2005 5:23 pm ]
And the water Pump, the gearbox casing, the remote housing, the oil filter housing, I'm sure there are other Alloy bits in there too .....
Can you Chrome a Block ?
he he he he "The King Of Bling" Lives....
J
Page 1 of 3 All times are UTC + 10 hours
