6 Blade metal fan https://www.ausmini.com/forums/viewtopic.php?f=2&t=76911 |
Author: | crisonic [ Fri May 25, 2012 9:45 pm ] |
Post subject: | 6 Blade metal fan |
Hi All Can any one tell me which way round a 6 blade metal cooling fan goes? Each blade is riveted to a mounting which is part of the centre piece Are the blades closest to the radiator or the engine Many Thanks |
Author: | justminis [ Sat May 26, 2012 7:18 am ] |
The blades go the radiator side of the centre mounting piece. You should be able to see the centre mounting piece from the engine side. The fan is "supposed" to run in line with the radiator shroud opening. Check that this fan clears everything before you start it! |
Author: | crisonic [ Mon May 28, 2012 8:42 am ] |
Post subject: | 6 blade metal fan |
Many thanks Steve |
