It is currently Sat Jul 26, 2025 1:00 am
PostPosted: Sun May 27, 2012 11:49 am
Hi
I have a 1978 square nose that has bailey channel surrounding windows but nothing else.
Need help picturing and purchasing requirements
Am I looking at inner door felt, outer door glass rubber and an outer chrome strip- hopefully all at the one shop. ( I am happy with chrome on window sill only , not absolutely necessary all way round window)
I can find the felt and rubber and the outer clips but not the outer chrome strip. If i can't find the chrome strip does the uk (mk 3 onwards) wind up windows - door moulding fit the leyland?
Example link http://www.minispares.com/Product.aspx?ty=pb&pid=38278&title=
Maybe I am just blind, have looked in Minisport, CP but not called yet
Cheers Darryl
PostPosted: Sun May 27, 2012 1:05 pm
i think you will struggle to find the outer chrome strips new
i am pretty sure i have some 2nd hand ones here tho
Matt
0407135656
PostPosted: Sun May 27, 2012 2:33 pm
Do you have "Clark Rubber " stores in Queensland??
They sell that channel insert....approx $6 /metre off the roll.
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Sun May 27, 2012 6:39 pm
Is that the felt or outer rubber?
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Sun May 27, 2012 6:43 pm
Ill go and check out clark rubber thanks
Matt , will pm you shortly
Cheers Darryl
PostPosted: Sun May 27, 2012 7:14 pm
The product I bought comes as a flat strip ... folded over ,it fits perfectly in the window channel...Use a bit of adhesive to hold in place.
Don't forget to buy the correct length... for the 1/4 window inside the lower door & at the rear as well as in the window frame....approx 1500mm each side.
CAMS Scrutineer
