It is currently Sun Jul 20, 2025 3:45 pm
PostPosted: Sat May 26, 2012 7:31 pm
hi guys,
I purchased a new mini which came with a smiths electric tachometer (RV1 1003/00 0-80 ) and I was told it was removed since the car has electronic ignition.
Whats the best way to wire in a tachometer without damaging the electrics?
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Sat May 26, 2012 7:39 pm
I don't think it matters, never had a problem on my cars.
PostPosted: Sat May 26, 2012 7:41 pm
Good :D
I will cautiously plug mine in tomorrow.
Cheers.
PostPosted: Sat May 26, 2012 7:48 pm
I took mine to Howard Instruments and had the smiths tacho converted to electronic to suit the 123 ignition dizzy I put on. It is perfect now but prior to that the needle was all over the place. I will be putting the original dizzy back on later but the tacho will work fine with that too I am told.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Sat May 26, 2012 7:49 pm
Mine has pulsar electronic ignition. If its all over the place tomorrow i'll look up an instruments place near by.
PostPosted: Sat May 26, 2012 7:52 pm
Smiths RV1 is old design, needs mods to work with electronic ignition.
Howard instruments in Melbourne are good for this, but I'd rather go buy a new (later) one, they work OK, then ebay the old RV1.
I also have Pulsar ignition, but my tacho is a 9000rpm Veglia Borletti out of one of my Fiats. Works fine...8)
PostPosted: Sat May 26, 2012 7:54 pm
Howard instruments in Melbourne are good for this, but I'd rather go buy a new (later) one, they work OK.
Would you recommend the smiths current model tachometer?
http://minispares.com/Product.aspx?ty=p ... 691&title=
PostPosted: Sat May 26, 2012 7:59 pm
Danny , i would take the tacho to a specialist gauge repairer and ask them before you hook it up , ( if youré not sure ) as it doesn't take much to spike the tacho and you could possibly stuff it .
There are plenty of different models in these tacho's , as well as a few different ways to hook them up .
PostPosted: Sat May 26, 2012 8:27 pm
I have one of the new ones from Minispares and the 123 dissy and it is all over the place Minispares sent me a replacement at no cost and its the same reads 0 at idle and jumps all over the place at road speeds jumps to 6-7000 at start up then falls back to 0
1970 Mk 2 Cooper S
PostPosted: Sat May 26, 2012 8:33 pm
My mate `4myego' bought a new Smiths one, we plugged it in with the Pulsar dizzy and Bosch coil and it works fine. Looks good too in his Mk2S. 8)
PostPosted: Sun May 27, 2012 4:19 pm
Go and see Barry at St George instruments Planthurst Rd and talk to him.
PostPosted: Sun May 27, 2012 5:49 pm
Thanks, I will pass by and ask him if its salvageable.
I opened it up to see if there were any broken components and one of the ceramic disc capacitors has blown or just fallen apart.
this is the kind of condition its in.
PostPosted: Sun May 27, 2012 5:50 pm
Meh I'd buy new. :wink:
PostPosted: Sun May 27, 2012 5:52 pm
Where is the fun in that :P
PostPosted: Sun May 27, 2012 5:59 pm
At my age I'm over fixing dodgy old stuff. Oh hang on, I drive a Mini... :roll: :wink:
