I was thinking along the line of arms. Having a look at a couple of my own cars I noticed the wiped motor appears to mount to the firewall and pass through to the scuttle / cabin air intake where the arms are mounted.
If using bars / arms & not the mini setup, may have to make up a bracket to get the motor at the right height / angle to mate up!
I think the curvature of the scuttle panel is going to be an issue too!
I've just been working on re running my wiring through a different hole in the firewall, the one behind the brake master, to clear up the area under the scuttle panel so nothing can foul the action of the bars / arms in action!
Cheers Shane
_________________ If it's not a Cooper S, the mini was designed to be modified!
