It is currently Thu Jul 24, 2025 1:19 am
PostPosted: Tue Jun 05, 2012 12:15 pm
I would like to know what this power plant is out of. Year Mod, type of vehicle etc.Is it of any use? Thanks
PostPosted: Tue Jun 05, 2012 12:30 pm
Sounds a bit like a Morris 1100s / 1300 unit from the 60s.
 Post subject: engine year date
PostPosted: Tue Jun 05, 2012 1:51 pm
If the engine has still got the distributor fitted
the month and year will be stamped into the body of the
LUCAS 29D distributor
part number AYG2153 12 68 ( dec 1968 )
This distributor was from a 1968 Morris 1100S, Engine number
12YE/A/H1385 (1275cc automatic engine)
Or just compare the above engine number to your engine number for a approx year/month date.
PostPosted: Tue Jun 05, 2012 3:22 pm
As said, it's from a Morris 1100S/1300 automatic.
It needs oilway mods to work on a manual box, see my sticky at top of the Mini mods forum.
I am running a manual converted one in my 1360 wasaMatic.
[edit] These 1275 + autoboxes don't go too bad dropped into a Mini, but the gearing is pretty low. Final drive ratio (overall including the drop gears) is 3.76:1.
You do need a MiniMatic subframe though, as the box is wider and sticks further forward too.
PostPosted: Tue Jun 05, 2012 4:32 pm
It is from a Morris 1300 automatic.
It is not from a Morris 1100S automatic.
So it would be between June 69 to April 72.
PostPosted: Tue Jun 05, 2012 4:40 pm
Q for Morris 1100-
Maaaate, I have a block here from an 1100S auto, it's 12H169/H321
Any idea what vintage? :lol:
PostPosted: Tue Jun 05, 2012 4:48 pm
Q for Morris 1100-
Jan 69 to May 69. Probably closer to Jan than May.
They only built the Morris 1100S automatic for five months and about 700 cars. The early cars had a fully imported powerplant with the 12H169/H and the later ones had the Australian produced one with the 12YA/A/H prefix.
PostPosted: Tue Jun 05, 2012 4:58 pm
So, were these 1275cc `australian produced' blocks & heads cast here, if so by whom? Or did they bring the blocks & bits in and assemble here?
PostPosted: Tue Jun 05, 2012 5:03 pm
I understand that they imported UK castings and machined them locally.
PostPosted: Mon Feb 18, 2013 11:29 am
I have just scored an old buggy that has a rear engined 1275 auto in it .
Engine no : 12YE / A / H xxxx
Dizzy No: 29 D
629 11 971 A
AYG 2153 3 69
I'm assuming from above comments that the motor comes from a march 69
Morris 1100 / 1300 .
It hasn't been run for some time , going to try to fire it up , not sure what í'll do with it ,
rough idea of what they'd be worth ? I'll see how i go with some photo's ( if i can figure it out the posting side of it ) .
PostPosted: Sun Feb 24, 2013 8:04 pm
Goodie can now post pictures
(tonight at least ) :D
PostPosted: Sun Feb 24, 2013 8:09 pm
That buggy looks fun but I'd toss the autobox and fit a 4 synchro manual instead.
And also mod the motor for more mumbo.
Autobox sucks too much POWA! :evil:
PostPosted: Sun Feb 24, 2013 8:20 pm
The Mini King
It May be a lot of work tofit the gear change though Kev
PostPosted: Sun Feb 24, 2013 8:27 pm
John I used to build Formula Vees, so a gearshift would NOT be a problem.
PostPosted: Sun Feb 24, 2013 8:55 pm
My brother actually scored the buggy , he's known about it for a couple of years .
He told me that it had a 1275 in it , so i asked him what he was going to do with it ,and
he said sell it , so i told him that i'd buy the motor out of it .
Well , we went out the other day to pick it up and thats when i noticed that it was an auto , unfortunately it has been sitting in the weather for 12 months so a couple of things need some attention .
Basically i'm going to try and fire it up , see what it does , whether it drives or not and then decide which bits i want to keep , take the engine out , get rid of the tranny
and palm the buggy off .
What engine / gearbox oil do these things take ?
Users browsing this forum: No registered users and 130 guests
