12YE/A/H.... with Auto Box WHATS IT FROM? https://www.ausmini.com/forums/viewtopic.php?f=2&t=77066 |
Page 1 of 2 |
Author: | origmini [ Tue Jun 05, 2012 12:15 pm ] |
Post subject: | 12YE/A/H.... with Auto Box WHATS IT FROM? |
I would like to know what this power plant is out of. Year Mod, type of vehicle etc.Is it of any use? Thanks |
Author: | Harley [ Tue Jun 05, 2012 12:30 pm ] |
Sounds a bit like a Morris 1100s / 1300 unit from the 60s. |
Author: | ALPINE MOKE [ Tue Jun 05, 2012 1:51 pm ] |
Post subject: | engine year date |
If the engine has still got the distributor fitted the month and year will be stamped into the body of the LUCAS 29D distributor part number AYG2153 12 68 ( dec 1968 ) This distributor was from a 1968 Morris 1100S, Engine number 12YE/A/H1385 (1275cc automatic engine) Or just compare the above engine number to your engine number for a approx year/month date. |
Author: | drmini in aust [ Tue Jun 05, 2012 3:22 pm ] |
As said, it's from a Morris 1100S/1300 automatic. It needs oilway mods to work on a manual box, see my sticky at top of the Mini mods forum. I am running a manual converted one in my 1360 wasaMatic. [edit] These 1275 + autoboxes don't go too bad dropped into a Mini, but the gearing is pretty low. Final drive ratio (overall including the drop gears) is 3.76:1. You do need a MiniMatic subframe though, as the box is wider and sticks further forward too. |
Author: | Morris 1100 [ Tue Jun 05, 2012 4:32 pm ] |
It is from a Morris 1300 automatic. It is not from a Morris 1100S automatic. So it would be between June 69 to April 72. |
Author: | drmini in aust [ Tue Jun 05, 2012 4:40 pm ] |
Q for Morris 1100- Maaaate, I have a block here from an 1100S auto, it's 12H169/H321 Any idea what vintage? ![]() |
Author: | Morris 1100 [ Tue Jun 05, 2012 4:48 pm ] |
drmini in aust wrote: Q for Morris 1100-
Maaaate, I have a block here from an 1100S auto, it's 12H169/H321 Any idea what vintage? ![]() Jan 69 to May 69. Probably closer to Jan than May. They only built the Morris 1100S automatic for five months and about 700 cars. The early cars had a fully imported powerplant with the 12H169/H and the later ones had the Australian produced one with the 12YA/A/H prefix. |
Author: | drmini in aust [ Tue Jun 05, 2012 4:58 pm ] |
So, were these 1275cc `australian produced' blocks & heads cast here, if so by whom? Or did they bring the blocks & bits in and assemble here? |
Author: | Morris 1100 [ Tue Jun 05, 2012 5:03 pm ] |
drmini in aust wrote: So, were these 1275cc `australian produced' blocks & heads cast here, if so by whom? Or did they bring the blocks & bits in and assemble here?
I understand that they imported UK castings and machined them locally. |
Author: | goodie [ Mon Feb 18, 2013 11:29 am ] |
I have just scored an old buggy that has a rear engined 1275 auto in it . Engine no : 12YE / A / H xxxx Dizzy No: 29 D 629 11 971 A AYG 2153 3 69 I'm assuming from above comments that the motor comes from a march 69 Morris 1100 / 1300 . It hasn't been run for some time , going to try to fire it up , not sure what í'll do with it , rough idea of what they'd be worth ? I'll see how i go with some photo's ( if i can figure it out the posting side of it ) . ![]() ![]() ![]() |
Author: | slacko [ Sun Feb 24, 2013 8:04 pm ] |
Goodie can now post pictures (tonight at least ) ![]() |
Author: | drmini in aust [ Sun Feb 24, 2013 8:09 pm ] |
That buggy looks fun but I'd toss the autobox and fit a 4 synchro manual instead. And also mod the motor for more mumbo. Autobox sucks too much POWA! ![]() |
Author: | John Smidt [ Sun Feb 24, 2013 8:20 pm ] |
drmini in aust wrote: That buggy looks fun but I'd toss the autobox and fit a 4 synchro manual instead.
And also mod the motor for more mumbo. Autobox sucks too much POWA! ![]() It May be a lot of work tofit the gear change though Kev |
Author: | drmini in aust [ Sun Feb 24, 2013 8:27 pm ] |
John Smidt wrote: drmini in aust wrote: That buggy looks fun but I'd toss the autobox and fit a 4 synchro manual instead. And also mod the motor for more mumbo. Autobox sucks too much POWA! ![]() It May be a lot of work tofit the gear change though Kev John I used to build Formula Vees, so a gearshift would NOT be a problem. |
Author: | goodie [ Sun Feb 24, 2013 8:55 pm ] |
My brother actually scored the buggy , he's known about it for a couple of years . He told me that it had a 1275 in it , so i asked him what he was going to do with it ,and he said sell it , so i told him that i'd buy the motor out of it . Well , we went out the other day to pick it up and thats when i noticed that it was an auto , unfortunately it has been sitting in the weather for 12 months so a couple of things need some attention . Basically i'm going to try and fire it up , see what it does , whether it drives or not and then decide which bits i want to keep , take the engine out , get rid of the tranny and palm the buggy off . What engine / gearbox oil do these things take ? |
