It is currently Tue Aug 05, 2025 12:36 pm
 Post subject: lube mkI door catch
PostPosted: Thu Jun 07, 2012 8:28 pm
What is a goood lube for a mk I style door catch?
PostPosted: Thu Jun 07, 2012 9:20 pm
I use lithium dry lube in a can. WD-40 make it under a different name,
I have used it on the boot lock, door hinges, strike plate, latch and the bonnet latch.
It all works smoothly now.
http://www.3inone.com.au/3inone/white_l ... grease.php
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Thu Jun 07, 2012 10:00 pm
I used graphite powder inside the lock, and a dry lube stick on the striker.
