hole in firewall needs to go https://www.ausmini.com/forums/viewtopic.php?f=2&t=77079 |
Author: | min-E [ Wed Jun 06, 2012 5:36 pm ] |
Post subject: | hole in firewall needs to go |
Ok I'm sure there are Alot of ideas and hopefully even some pics of how you covered the massive hole behind your gauges? Im have a few rough ideas but I would like to see what some of you guys have done. Cheers Pete |
Author: | Morris 1100 [ Wed Jun 06, 2012 5:59 pm ] |
Get the plate that the factory fitted in the 70s before they deleted the hole. |
Author: | Fiji [ Wed Jun 06, 2012 6:35 pm ] |
I need to do this also. But majority of my wiring runs through there & speedo cable. May have to make up a plate at work then buy bulkhead sound deadening . |
Author: | mattsmadmini [ Wed Jun 06, 2012 6:46 pm ] |
![]() Best fill of a hole ive ever seen ![]() |
Author: | willy [ Wed Jun 06, 2012 7:14 pm ] |
Beautiful pic Matty |
Author: | AEG163job [ Wed Jun 06, 2012 9:27 pm ] |
That is HOT! |
Author: | drmini in aust [ Wed Jun 06, 2012 9:51 pm ] |
AEG163job wrote: That is HOT!
Needs a set of DrMini stubstacks, or a pair of trumpets on it. I like the easy firefighting access... ![]() |
Author: | Fiji [ Wed Jun 06, 2012 10:42 pm ] |
![]() Ahhhh ... now you can swear directly at it when it won't start. |
Author: | sgc [ Wed Jun 06, 2012 11:01 pm ] |
Nick's: ![]() Hanra's: ![]() |
Author: | Molina [ Thu Jun 07, 2012 12:00 am ] |
Mine ... http://i364.photobucket.com/albums/oo90 ... 4-Copy.jpg |
Author: | min-E [ Thu Jun 07, 2012 12:47 am ] |
Thanks guys some nice pics and great ideas. |
Author: | Curly [ Thu Jun 07, 2012 6:16 am ] |
This shallow, fireproof 'airbox' is what the Group N cars are now allowed. All the wiring that normally runs through the area has to be re-routed and the oval dashboard speedo binacle is moved inwards about 1" further and that takes a fair bit of fiddling around; but it's certainly an improvement over what was allowed previously. All the guages and speedo in my S still work as noted by the speedo cable still in place. ![]() |
