Little question about 998s
https://www.ausmini.com/forums/viewtopic.php?f=2&t=77085
Author:  Speedwell Racer [ Wed Jun 06, 2012 8:21 pm ]
Post subject:  Little question about 998s
Hey guys,
Im just wondering what the record is for the most amount of ponnies produced by a 998 with a 5 port head.
My mate has a 998 with a 5 port head and its had thousands spent on it including a dual stage down draft weber, bored 110 thou and massive head work.
He is now planing on putting a turbo on it and expects 150hp.
So just wondering if he could really get that sort of power from a 998.
Cheers, Rhys.
Author:  mini1990 [ Wed Jun 06, 2012 8:41 pm ]
With enough money I guess anything is possible.
Check these guys out: they are trying to break the under 1000cc land speed record with a mini and have managed to ring 240hp out of their 998. Albeit with an extra cam and a turbo.
http://www.ausmini.com/forums/viewtopic.php?t=76799
Author:  adamstuart [ Wed Jun 06, 2012 11:30 pm ]
150hp can be had from a turbo 998.
Wil_H on turbo minis has a 13second 998.
"Circa 155 BHP at 6900 rpm, 125 ftlb @ 5900 rpm"
Twin turbo UK
Author:  Irish Yobbo [ Thu Jun 07, 2012 11:03 am ]
It's important to remember what you want the power for though. The guys at Project 64 are doing an amazing job, but the engine will probably die after a thousand ks.
I really like seeing people getting huge power out of the a series, but if you're going for practicality, you'd be better off going for an engine transplant. You'll get the power, along with the reliability and fuel economy.
But as I said, modding the a series is fun.
Author:  drmini in aust [ Thu Jun 07, 2012 1:58 pm ]
Just remember, a low compression 998 turbo when it's `off boost' is pretty gutless. Not real great in traffic. Hence why when building a turbo (for road use) many people use a 1098, not a 998. So pushbikes don't leave ya at the lights before you're spooled up. :wink:
Author:  sgc [ Thu Jun 07, 2012 2:06 pm ]
The other thing is by extracting 150HP (at the wheels?) from a 998 you're building a grenade.. it's just a matter of time before it goes BANG! and showers the cyclists in oil and conrods...
Author:  Kennomini [ Thu Jun 07, 2012 8:39 pm ]
if it's bored out it's not a 998 :wink:
Personally If I was building a "998" I'd get a good head and make it flow really well, decent to excessive cam and forced induction.
If you bore it out your building an 1100.
Author:  sgc [ Thu Jun 07, 2012 8:58 pm ]
No you're not! If you stroke it, it's an 1100 ;)
Author:  drmini in aust [ Thu Jun 07, 2012 9:56 pm ]
THEN you bore it out. :P
Don't go silly with the overbores if turboing it, +.060" or +.080" is enough. Whether it's got a 1098 crank, or not.
As for cams- don't go too big, or the valve overlap will send more of the boost down the zorst while both valves are open.
I'd get one of GR's T cams, either the 83T or the 13T.
Author:  Kennomini [ Fri Jun 08, 2012 7:06 pm ]
alright then, it's an 1108 (if my maths is correct :? )
Author:  drmini in aust [ Fri Jun 08, 2012 8:03 pm ]
A 998 bored overbored to +.120" is 1095.5cc.
I'd not be turboing it with cylinder walls this thin though. :wink:
