It is currently Mon Aug 04, 2025 7:46 am
PostPosted: Sat Jun 09, 2012 3:47 am
Ok so it was in at one stage before i started the rebuild but I only had it a day before i stripped it down so i don't know if it did fit well before. Now, the top and bottom of the screen are fairly tight yet the bottom corners are very loose and by loose I mean one side I can pull the rubber back and see an estimated gap of about 10mm. I'm guessing they have done some cut and shut somewhere along the lines before i got it and like most of the workmanship I have found on it was very Dodgy.
Any ideas what I can do?
Cheers Pete
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Sat Jun 09, 2012 7:54 am
Is there clearly evidence of repair work around the windscreen lips?
I would make measurements of all the sides and the diagonals to see how square it is too, which might indicate the problem.
Ive got probably 2-3 front windscreens here if you wanna try some others?
PostPosted: Sat Jun 09, 2012 1:21 pm
hmmm, windscreen lips...
First you get the money,then you get the power,then you get the Mini.
PostPosted: Sat Jun 09, 2012 7:13 pm
is it a new or old screen, i have heard that some of the Chinese (new) screens are poor quality
also measure the screen
PostPosted: Sat Jun 09, 2012 8:34 pm
Put your locking strip in it first the rubber deforms a fair bit with the strip in it.
G.
1962 Mini Speed sports sedan
PostPosted: Sat Jun 09, 2012 10:39 pm
Since the rebuild we have noticed there has been a few odds and ends in some panels. Father inlaw has his old van stripped under the house might try his rubber and screen
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Sat Jun 09, 2012 11:14 pm
Poor chink quality? Well, what a surprise.............................. :roll:
I go out of my way to avoid buying anything Chinese these days.
