front windscreen doesnt seem to fit https://www.ausmini.com/forums/viewtopic.php?f=2&t=77114 |
Author: | min-E [ Sat Jun 09, 2012 3:47 am ] |
Post subject: | front windscreen doesnt seem to fit |
Ok so it was in at one stage before i started the rebuild but I only had it a day before i stripped it down so i don't know if it did fit well before. Now, the top and bottom of the screen are fairly tight yet the bottom corners are very loose and by loose I mean one side I can pull the rubber back and see an estimated gap of about 10mm. I'm guessing they have done some cut and shut somewhere along the lines before i got it and like most of the workmanship I have found on it was very Dodgy. Any ideas what I can do? Cheers Pete |
Author: | mini1990 [ Sat Jun 09, 2012 7:54 am ] |
Is there clearly evidence of repair work around the windscreen lips? I would make measurements of all the sides and the diagonals to see how square it is too, which might indicate the problem. Ive got probably 2-3 front windscreens here if you wanna try some others? |
Author: | minimy [ Sat Jun 09, 2012 1:21 pm ] |
hmmm, windscreen lips... |
Author: | kiwiinwgtn [ Sat Jun 09, 2012 7:13 pm ] |
is it a new or old screen, i have heard that some of the Chinese (new) screens are poor quality also measure the screen |
Author: | low n blown [ Sat Jun 09, 2012 8:34 pm ] |
Put your locking strip in it first the rubber deforms a fair bit with the strip in it. G. |
Author: | min-E [ Sat Jun 09, 2012 10:39 pm ] |
Since the rebuild we have noticed there has been a few odds and ends in some panels. Father inlaw has his old van stripped under the house might try his rubber and screen Cheers |
Author: | AEG163job [ Sat Jun 09, 2012 11:14 pm ] |
kiwiinwgtn wrote: is it a new or old screen, i have heard that some of the Chinese (new) screens are poor quality
Poor chink quality? Well, what a surprise.............................. ![]() I go out of my way to avoid buying anything Chinese these days. |
