It is currently Sat Jul 26, 2025 11:05 am
 Post subject: rc40
PostPosted: Sat Jun 09, 2012 2:07 pm
hi all just wondering how the centre mount rc40 ataches to the rear k frame. pics would be great cheers
PostPosted: Sat Jun 09, 2012 4:54 pm
I assume you mean a centre exit muffler?
Measure and find the centre of the subframe,at the back of the car.
Then measure the distance betwen the two mounting holes and transfer that measurement to the subframe, bearing in mind to centre this measurement.
Then drill holes at these two points so you can fit two cotton reel rubber mounts.
Bolt in the mounts and then mount your muffler. The front of the muffler I used a normal Cooper S type bracket and straightened the twist out.
Sorry no photos as I haven't worked out how to post from an iPad
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jun 10, 2012 9:22 pm
Like this.
Dalmeny
PostPosted: Mon Jun 11, 2012 7:18 am
There are usually two holes that will allow you to fit a cooper s rear exhaust mount in the middle (these are cheap and pretty).
PostPosted: Mon Jun 11, 2012 9:03 am
dalmeny wrote:
Like this.
That is a sweet looking mini you have their 8) .
(Someone will go mad at you for not using proper jack stands though)
PostPosted: Mon Jun 11, 2012 10:50 am
Personally i'd rather a huffin' big block of wood with an 8" surface area than a jack stand with a 6" and 2" surface area on the other end
You're so square
Baby I don't care
PostPosted: Mon Jun 11, 2012 11:24 am
dalmeny wrote:
This works fine, except you will also need an exhaust to connect to the muffler B)
Nothing wrong with using rounds of wood as axel stands, but best to mount it from the subframes. I spent a long time trying to bash the floorpan back into shape from where it was previously jacked up.
PostPosted: Mon Jun 11, 2012 12:09 pm
It probably didnt have a subframe attached when it was put on the logs? :wink:
68 Mini
70 Moke
PostPosted: Mon Jun 11, 2012 12:24 pm
It's on the corner though, where lots of panels meet and is quite a strong area, as opposed to the middle of the floor where everyone has jackinthewrongspot dents.
And I don't believe there were subframes in it at the time no
You're so square
Baby I don't care
PostPosted: Mon Jun 11, 2012 6:48 pm
Correct, it's where you put them that makes the difference. No squashed floors here!
Dalmeny
PostPosted: Mon Jun 11, 2012 9:53 pm
DALMENY.
Gotta say, the paint finish is billiant. Is that two pack?
Carefull with those tree stumps. Their only good for about 70 tons each!
Alex.
PostPosted: Mon Jun 11, 2012 10:55 pm
haze blue 850 wrote:
DALMENY.
Alex.
Yeah, two pack on the outside and Raptor ute bedliner on the underside. (There is a rebuild thread in the members gallery)
Dalmeny
PostPosted: Tue Jun 12, 2012 11:34 am
Here is my centre mount RC40.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Jun 12, 2012 10:59 pm
I can't see the mounting points. :roll:
PostPosted: Wed Jun 13, 2012 7:13 am
Can you read? michaelb gave a pretty detailed description of them above. That along with the photo pretty much says it all.
Users browsing this forum: minimanic and 80 guests
