It is currently Fri Jul 18, 2025 6:59 pm
PostPosted: Sat Jun 16, 2012 7:45 am
Hi Guys,
Hoping to pick your brains for advice, went out just now to take the mini for a run before the showers hit, and I couldn't get it to start. The starter motor was spinning up making a sound sort of like the whine of a cordless drill rather than the usual rumbling sound, kind of like it wasn't engaged? Even when the battery has been too flat to start it has been more of a sad coughing sound rather than this. I last drove the car about a week ago.
Any advice?
Nick
Basil - 1978 Leyland Mini, Brooklands Green, bit of a bitsa, and a park brick in the boot. :)
PostPosted: Sat Jun 16, 2012 8:19 am
It will happen if the bendix gear is dry and the pinion can't slide down it. You need to pull the starter out, clean the shaft and pinion and lubricate it with a light lubricant. It can be worse if the battery is flat.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sat Jun 16, 2012 9:28 am
Cheers for that I'll give it a go tomorrow morning when I have some free time.
Any particular lubricant you recommend? All i have sitting around is engine oil and bearing grease :) I'm guessing neither of those.
Thanks again!
PostPosted: Sat Jun 16, 2012 9:46 am
Don't use oil or grease (or WD40). They pick up dust and make it stick.
1. Wash the bendix drive with thinners. let it dry.
2. Sprinkle with powdered graphite (available from Bunnings etc).
PostPosted: Sat Jun 16, 2012 3:27 pm
Thanks Doc, I'll get some graphite then
Thanks again guys
Nick
PostPosted: Sat Jun 23, 2012 10:26 am
Well I just got the starter back in, went to turn it over and the battery is now flat :) but I could still hear it engaging now rather than the mad spinning from last week. Hopefully a day on the charger sees it all sorted.
Thanks for the help
Nick
