It is currently Sun Jul 20, 2025 8:29 am
PostPosted: Sun Jun 24, 2012 7:11 pm
Hey guys
I have a set of metro 4 pot calipers to put on my clubman, is a booster needed? Also where does the vacuum come from to operate the booster?
PostPosted: Sun Jun 24, 2012 7:35 pm
I'm not using a booster on my mini with 4 spot Minisport calipers and the brakes feel OK, not as easy pedal pressure as my Coopr S but much better than drums. Probably a Personel choice
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jun 24, 2012 8:48 pm
I've got Metro 4 pots on the Moke with no booster and a standard m/c. They're very effective under normal braking conditions and extremely good if you really step on the pedal hard.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sun Jun 24, 2012 8:59 pm
Cool thanks for the reply, probably won't go with one just needed some options to see if it needed one
PostPosted: Mon Jun 25, 2012 12:28 am
Your choice of pads will also affect the pedal pressure needed. I use drums, but I hear that greenstuff pads are pretty good for a lighter pedal.
The vacuum needs to be taken from the inlet manifold, which means either modifications to the original, or a new manifold (which means a new exhaust manifold too). The original is a joint inlet/exhaust manifold, to replace one you need the other unless you cut the stock one.
PostPosted: Mon Jun 25, 2012 6:10 am
A booster is never needed unless you have a particularly weak leg, or you live somewhere where the rules dictate it. It 's preference/feel thing.
I metro vented with greenstuffs. Put you through the windscreen without even trying.
