Crown wheel and pinion
https://www.ausmini.com/forums/viewtopic.php?f=2&t=77243
Author:  smac [ Wed Jun 20, 2012 4:38 pm ]
Post subject:  Crown wheel and pinion
I've seen these sets advertised as "to suit A+" and also as "suit any gearbox".
What's the go? :?:
Author:  MiniVLT [ Wed Jun 20, 2012 5:27 pm ]
A+ gearbox gears are cut at a different helical angle, so you can't mix pre & post gears.
Cheers Shane
Author:  EST-071 [ Wed Jun 20, 2012 6:49 pm ]
Cheers Shane
This is correct however you can run A+ diff gears in any gearbox. Some may need a little clearance work around the pinon but is not that hard.
Cheers Pete
Author:  kiwiinwgtn [ Wed Jun 20, 2012 7:04 pm ]
I am running a 3.1 a+ in my non Aplus box.
You have to machine the 3rd motion shaft retainer a little to get clearance for the pinion.
You will also need less diff shims as the crown wheel is slightly wider.
Kiwiinwgtn
Author:  smac [ Wed Jun 20, 2012 7:21 pm ]
Ya I knew the gear sets were different teeth but knew there must be a reason major parts suppliers list them as 'all boxes'.
Thanks for the info.
Author:  bnicho [ Wed Jun 20, 2012 8:44 pm ]
I'm going the other way - A series NOS 3.93 gearset into an A+ box. So I will need extra shims I guess.
