What is the weight of a 521 rod? https://www.ausmini.com/forums/viewtopic.php?f=2&t=77278 |
Page 1 of 2 |
Author: | TK [ Sat Jun 23, 2012 1:47 pm ] |
Post subject: | What is the weight of a 521 rod? |
In grams please without bolts. Thanks heaps. |
Author: | drmini in aust [ Sat Jun 23, 2012 2:39 pm ] |
Stock AEG521 rod + cap, 608g I just measured, with bolts out. 2x ARP `BB Ford' rod bolts + nuts, add another 84g. There are 2 versions of a 521- have caps with, or without cutouts. This one is without. (but there's not much weight difference). |
Author: | TK [ Sat Jun 23, 2012 8:18 pm ] |
thanks Kev |
Author: | dalmeny [ Sat Jun 23, 2012 8:32 pm ] |
drmini in aust wrote: Stock AEG521 rod + cap, 608g I just measured, with bolts out.
2x ARP `BB Ford' rod bolts + nuts, add another 84g. There are 2 versions of a 521- have caps with, or without cutouts. This one is without. (but there's not much weight difference). Dr Would you have a part number for those ford rod bolts? Thanks Steve |
Author: | drmini in aust [ Sat Jun 23, 2012 9:18 pm ] |
dalmeny wrote: drmini in aust wrote: Stock AEG521 rod + cap, 608g I just measured, with bolts out. 2x ARP `BB Ford' rod bolts + nuts, add another 84g. There are 2 versions of a 521- have caps with, or without cutouts. This one is without. (but there's not much weight difference). Dr Would you have a part number for those ford rod bolts? Thanks Steve ARP's # is 155-6002. 16 to a set, I buy from http://www.vpw.com.au/Category/Index/6680 ~$74 a set of 16! + post. ![]() Beats S ones don't it... Others note- these are 3/8" bolts, they don't fit 1275 big journal rods which have 11/32" bolts.. |
Author: | dalmeny [ Sun Jun 24, 2012 9:19 pm ] |
drmini in aust wrote: dalmeny wrote: drmini in aust wrote: Stock AEG521 rod + cap, 608g I just measured, with bolts out. 2x ARP `BB Ford' rod bolts + nuts, add another 84g. There are 2 versions of a 521- have caps with, or without cutouts. This one is without. (but there's not much weight difference). Dr Would you have a part number for those ford rod bolts? Thanks Steve ARP's # is 155-6002. 16 to a set, I buy from http://www.vpw.com.au/Category/Index/6680 ~$74 a set of 16! + post. ![]() Beats S ones don't it... Others note- these are 3/8" bolts, they don't fit 1275 big journal rods which have 11/32" bolts.. Thanks Kev Buy a set and throw the other half on here for $30!!! Steve |
Author: | drmini in aust [ Sun Jun 24, 2012 9:30 pm ] |
I use them for engine builds, get 2 done per blister pack. ![]() Note their heads are a different shape, but they fit. Steel spec is same as ARP's S ones, but the flanged nuts are hex head, not 12 point. |
Author: | TheMiniMan [ Mon Jun 25, 2012 11:27 am ] |
yeah i`ve been using them for about 25 years ![]() ![]() ![]() |
Author: | 9/61 [ Tue Jun 26, 2012 1:51 pm ] |
Just to confirm, Doc wrote; ARP `BB Ford' rod bolts & then later wrote; ARP's # is 155-6002. On the vpw site it has, ARP-155-6002 Ford FE rod bolt kit under that # Is this the correct bolt kit? |
Author: | drmini in aust [ Tue Jun 26, 2012 3:30 pm ] |
Yes. FE is a Ford bigblock. |
Author: | 9/61 [ Tue Jun 26, 2012 4:37 pm ] |
Cheers Doc. |
Author: | TheMiniMan [ Tue Jun 26, 2012 5:29 pm ] |
yeah i`m pretty sure there are a couple of BB ford rod types, hence the 2 types of rod-bolts to suit ![]() |
Author: | Morris 1100 [ Tue Jun 26, 2012 6:29 pm ] |
In Ford terms the FE is not a big block. It is an FE block. |
Author: | drmini in aust [ Tue Jun 26, 2012 7:01 pm ] |
Morris 1100 wrote: In Ford terms the FE is not a big block. It is an FE block.
Well yeah it's midsize then, ![]() It started out as a 332 in 1958, then 352, 390, 406, 410, 427, finally 428 Cobra Jet). It's not a small engine, size wise. Weighs 650 lbs... http://phystutor.tripod.com/stang/engines/fe.html |
Author: | simon k [ Tue Jun 26, 2012 7:59 pm ] |
drmini in aust wrote: dalmeny wrote: drmini in aust wrote: Stock AEG521 rod + cap, 608g I just measured, with bolts out. 2x ARP `BB Ford' rod bolts + nuts, add another 84g. There are 2 versions of a 521- have caps with, or without cutouts. This one is without. (but there's not much weight difference). Dr Would you have a part number for those ford rod bolts? Thanks Steve ARP's # is 155-6002. 16 to a set, I buy from http://www.vpw.com.au/Category/Index/6680 ~$74 a set of 16! + post. ![]() Beats S ones don't it... Others note- these are 3/8" bolts, they don't fit 1275 big journal rods which have 11/32" bolts.. so these don't need to be machined like the set you sold me once? |
