4 pot caliper, booster nedded? https://www.ausmini.com/forums/viewtopic.php?f=2&t=77295 |
Author: | Snotz78 [ Sun Jun 24, 2012 7:11 pm ] |
Post subject: | 4 pot caliper, booster nedded? |
Hey guys I have a set of metro 4 pot calipers to put on my clubman, is a booster needed? Also where does the vacuum come from to operate the booster? |
Author: | michaelb [ Sun Jun 24, 2012 7:35 pm ] |
I'm not using a booster on my mini with 4 spot Minisport calipers and the brakes feel OK, not as easy pedal pressure as my Coopr S but much better than drums. Probably a Personel choice |
Author: | Timbo [ Sun Jun 24, 2012 8:48 pm ] |
I've got Metro 4 pots on the Moke with no booster and a standard m/c. They're very effective under normal braking conditions and extremely good if you really step on the pedal hard. Tim |
Author: | Snotz78 [ Sun Jun 24, 2012 8:59 pm ] |
Cool thanks for the reply, probably won't go with one just needed some options to see if it needed one |
Author: | Irish Yobbo [ Mon Jun 25, 2012 12:28 am ] |
Your choice of pads will also affect the pedal pressure needed. I use drums, but I hear that greenstuff pads are pretty good for a lighter pedal. The vacuum needs to be taken from the inlet manifold, which means either modifications to the original, or a new manifold (which means a new exhaust manifold too). The original is a joint inlet/exhaust manifold, to replace one you need the other unless you cut the stock one. |
Author: | smac [ Mon Jun 25, 2012 6:10 am ] |
A booster is never needed unless you have a particularly weak leg, or you live somewhere where the rules dictate it. It 's preference/feel thing. I metro vented with greenstuffs. Put you through the windscreen without even trying. |
