Engine balancing/machining Melb SE suburbs
https://www.ausmini.com/forums/viewtopic.php?f=2&t=77332
Author:  coopar [ Thu Jun 28, 2012 2:30 pm ]
Post subject:  Engine balancing/machining Melb SE suburbs
Who's best for balancing/machining mini engine parts in the SE of Melbourne?
Author:  Davo111 [ Thu Jun 28, 2012 3:21 pm ]
Flute or Harley will pop up anytime now..... :wink: :wink: :wink:
Author:  Drewie [ Thu Jun 28, 2012 3:50 pm ]
Pretty sure Link send all their Mini engines to a place called C W Engines in Nunawading. It has been a few years since I needed any maching but at the time that is were Bryan was sending his engines for boring etc.
Author:  coopar [ Thu Jun 28, 2012 3:57 pm ]
Nice one ill try them
Author:  Flute [ Thu Jun 28, 2012 7:42 pm ]
Yes, if you are that close it would be the way to go. Lindsay Seibler is a bit further out at Coldstream and he could point you in the right direction as well.
http://www.minis.com.au/
Author:  coopar [ Thu Jun 28, 2012 10:37 pm ]
Yep didn't call Lindsay, to stay local
Author:  CARTER_GT [ Fri Jun 29, 2012 12:03 am ]
Your missing out then. Without doUnt the best mini business in melbourne
Author:  coopar [ Fri Jun 29, 2012 9:46 am ]
Dont get me wrong, I buy alot off Lindsay but in this case I figured that he would suggest I take my whole engine out to Coldstream, then to the machinists then home.
Nunawading is much closer!...
Author:  Harley [ Fri Jun 29, 2012 10:17 am ]
Had all this stuff done when my engine was rebuilt 6 months ago. I'll have a dig through and see if I can find where stuff was done but I doubt I have it in detail.
Author:  norm74 [ Fri Jun 29, 2012 3:29 pm ]
you can try BnB engines in Clayton, they are on westall rd.
They do balancing, crankgrinding, flywheel machining rod resizing. boring and honing and head repairs.
they have done heaps of mgs, and austin 7 stuff.
Author:  850man [ Fri Jun 29, 2012 6:07 pm ]
Orger Engines in Bayswater
Crankshaft Rebuilders in Blackburn
Ken Hastings in Heidelberg
Motor Improvements in Moorabbin
Author:  CARTER_GT [ Mon Jul 02, 2012 12:50 am ]
The last one on that list are good for f**king up 2 GT blocks...
Author:  850man [ Mon Jul 02, 2012 8:15 am ]
Maybe the were ****ed before they got there. :shock:
Author:  CARTER_GT [ Mon Jul 02, 2012 9:19 am ]
Negative. The first one they ruined the didn't offset the bore right for a Stroker, next one the went an extra .40 thou oversize making the block usefull as it was to big
