It is currently Sat Aug 02, 2025 12:47 pm
PostPosted: Sat Jun 23, 2012 1:18 pm
Hi guys,
I decided to re bleed my brakes as they were a little bit spongy when i took it for a drive last week, I unscrew the right hand side brake bleed nipple half a turn and the thing just keeps turning. The thread on the nipple seems ok but the thread on the brake caliper has perished and i can move the nipple in and out without having to screw it.
What is the best way to fix this problem?
do i need to buy a whole new caliper set up?
they are 4 pot minispares calipers.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Sat Jun 23, 2012 1:26 pm
Take the caliper off and take it to a specialist brake place and see if they can put a larger bleed nipple in or put a thread recoil in for you.
68 Mini
70 Moke
PostPosted: Sat Jun 23, 2012 1:30 pm
I'm sure this came up recently. Probs just helicoil or tap a new thread for different nipple size.
PostPosted: Sat Jun 23, 2012 1:32 pm
Is it easy enough to tap in a new thread?
PostPosted: Sat Jun 23, 2012 2:17 pm
Only if you know what you are doing, have the equipment and tools.
In your case I'd take it to a brake place, as there are no 2nd prizes if you eff it up. :wink:
It's brakes mate, get it done right for safety...
PostPosted: Sat Jun 23, 2012 2:20 pm
I took the caliper off and had a look at the thread and thought it would be easier if they did it as the walls looked pretty thin.
PostPosted: Sat Jun 23, 2012 2:28 pm
It's not just a matter of a new thread- it has to be dead central with the port, or else put a ball bearing in between a new (shortened) nipple and the port.
PostPosted: Sat Jun 23, 2012 3:11 pm
My Minisport 4 pots have a steel insert in the alloy caliper which I assume helps prevent stripping the thread of the bleed nipple.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jun 23, 2012 4:46 pm
Ya the recent case was me.
I went to a 10mm thread to get enough bite.
As above if you don't get the new thread exactly right the tip of the bleeder won't centre in the hole and you get no seal.
I had to flatten off the bleeder and used a ball bearing. Seals perfectly, the only down side is because there's only just enough meat for the thread as soon as you crack the bleeder fluid comes out the thread as well as the bleed hole. Messy, but works. If/when I have cause to have the car off the road I'll get it redone properly.
PostPosted: Sat Jun 23, 2012 5:46 pm
Mine date back to the late 90's i think and its just aluminium throughout.
PostPosted: Sun Jun 24, 2012 4:08 pm
I'd take the other one off and get it done at the same time
PostPosted: Tue Jun 26, 2012 2:22 pm
A bit late now :(
I just picked it up from Sydney brake and clutch exchange.
$55 and 4 hours later.
They put an adaptor and a smaller nipple,
They did a pressure test and itseems to work well.
I am going to have the car off the road for another 4 weeks, if the other caliper plays up within that time I am goingto bring it back.
I hate posting from an iPhone.
PostPosted: Tue Jun 26, 2012 3:15 pm
That sounds serious Danny. :shock: Are you fixing the clutch adjustment?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Jun 26, 2012 3:48 pm
I am going to try and fix it, I seem to have forgotten what i need to get :/
It's only off the road because i can't drive it till the 26th of july :x
PostPosted: Sun Jul 01, 2012 2:14 pm
haha i should of listened to you first time.
The other caliper has decided to play up too...
The nipple rounded off the second i put the spanner on it and the thread where the brake line goes into perished... I will take them both back tomorrow so i can get both threads fixed so it doesnt happen in the future..
