So i'm just looking at some clutch plates and it's got me wondering.
What are the differences between verto and pre verto clutch plates? Going off of the minispares site we have
http://www.minispares.com/product/Class ... HT597.aspx Which says it is pre 1990 verto, but in the description it says performance type verto 180mm. This product is listed in the pre verto category and not the verto as there is a 190mm version listed for after 1990verto
So do verto come in 180mm and 190mm depending on the year? And having a spring center as opposed to pre verto having a solid center?
Getting more to the point, the clutch plate linked above is designed for both verto and pre verto as the solid center setup will work in both types?
