It is currently Sun Aug 17, 2025 1:26 am
 Post subject: Engine block
PostPosted: Tue Jul 03, 2012 5:48 pm
Hi All,
I am looking at buying a used bare engine block. Just like to know what to look out for? Obviously bore size but what else?
Thanks
PostPosted: Tue Jul 03, 2012 7:09 pm
damage around the centre main where the thrusts sit
PostPosted: Tue Jul 03, 2012 7:17 pm
1. Cracks between the bores at the top deck. Not common but does happen.
2. Check the 3 main caps are original, best done by measuring diameter but a fingernail on the joints will usually show if they don't belong.
Caps were line bored with the block originally.
A block with no caps = a doorstop (unless you want to pay for a set of new steel ones and a line bore job).
