Mokesta wrote:
With JC coming over to collect an Aussie rack I thought I would finish off the table at the top. The result is that the common Australian Cam Gears Patent racks are almost the same as the earlier ones in the 850.
I think my new car has one of those UK quick racks in it.
I'm not going to do it but it would be interesting to work out how much the extra throw of the Rover or UK racks reduces the turning circle of the mini.
M
The early racks look similar to the Cam Gears AYA6001, but the rack inside is smaller diameter, the pinion has 6 finer pitch teeth not 5, and none of the later bits fit it, including the tie rods.
The AYA6001 rack is actually a short version of a Morris 1100 rack, that's why it is bigger diameter bits inside..
re late Mokes, Mini King gets Morris 1100 tierods fitted to these Cam Gears racks for them, so you get another 12mm? thread engagement into the tierod ends.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
