It is currently Wed Jul 23, 2025 12:05 pm
PostPosted: Sat Jun 04, 2005 4:04 pm
Hey all, finally got around to diagnosing the Brick...
Guess what?
ANOTHER FREAKING HEAD GASKET !!
I was pretty sure that the head is a little warped, now I'm sure....
Less than 150Km on this one (Pair, actually)
Clean Burn, right between 2 and 3.. same place it went the last two times...
I would expect that if it was purely detonation causing it, it would be more "Random" on the cylinder that it targets... but its always between 2 and 3 ...
Heads off to the machine shop on Monday.....
Kev, maybe time to talk about one of your "DRMini Specials" ..........
J
PostPosted: Sat Jun 04, 2005 4:31 pm
james,, wouldnt have anything to do with them two leads being in the wrong spot maybe?? have you tried the acl gasket? Did u re torque the head? spose there are a few reasons why they keep blowing,, nothing to do with running 30psi of boost :D
1974 Moke - 998cc
PostPosted: Sat Jun 04, 2005 4:39 pm
Shhhh, it was only 16Psi on saturday....
Nahh, the leads were right to start with and they were only wrong for about 30 seconds.....
Just a nice warped head..... (sounds like something Mrs KazJim says about me..... hhhmmmmm)
J
PostPosted: Sat Jun 04, 2005 4:56 pm
Jim....
If you want to try the ACL gaskets let me know...
Ive been a lazy git and still not gotten you a price. :oops:
[Maverick] 1971 Mini K
PostPosted: Sat Jun 04, 2005 5:01 pm
Yes, Yes Yes !!
I'll grab a few and make it worth your time....
Make it 3 ?
Also, can you get the steel-backed Inlet / exhaust gaskets ? (Rover ones... EXCELLENT!!)
Thanks...
J
PostPosted: Sat Jun 04, 2005 5:10 pm
kazjim wrote:
Yes, Yes Yes !!
Make it 3 ?
Thanks...
J
I'll have to check the inlet/exhaust gaskets....I'll pay them a vist on monday and order some in if the price isnt too rough..It shouldn't be really.
And then Ill post you a PM..sound good?
PostPosted: Sat Jun 04, 2005 5:24 pm
James, just fit a 940 or 1316 head, and BK450 turbo gasket = no more problems! Chamber size = whatever you want up to 30cc or so.
ALL the smallbore heads flex more than the bigass 1275 ones do. :wink:
PostPosted: Sat Jun 04, 2005 5:34 pm
Only problem kev... you cleaned me out !
I'll have to chat with you by email.....
Got a 1316 almost ready to go ?
we'll work out a $$$ ... k ?
MiniK... maybe hold off... i might need to order a different head gasket yet.....
J
PostPosted: Sat Jun 04, 2005 6:51 pm
Take your pick James--
#1, 12G1316- needs exhaust seats but that's no problem to get done. I have some Rover unleaded inserts.
#2, 12G1316- G.R. & I fixed the rusted inlet seat with a 4140 insert, it just needs all seats recut now and it's a goer.
Both heads are bare now but I have 1 set of valves-
If I were you I'd buy new ones. They are pretty cheap now.
1100S inlets 12G941 $14.12 each
1275 exhausts 12G1322 $20.32 each.
Karcraft's prices- not worth mucking about with S/H is it. :wink:
