Temp gauge
https://www.ausmini.com/forums/viewtopic.php?f=2&t=77528
Author:  1976miniss [ Tue Jul 10, 2012 9:29 am ]
Post subject:  Temp gauge
Is there a best way to determine what's wrong with a temp gauge? I have changed the dash over and the gauge has not worked in either of them .
Author:  Anto [ Tue Jul 10, 2012 2:38 pm ]
Start by shorting out the sender unit wire onto the engine block. The gauge should read maximum.
If nothing changes then check the gauge has power. The circuit board on the clubman instrument cluster isn't the best of things and the traces break sometimes, so check it for continuity.
If the gauge reads maximum when the sender unit wire is shorted out, but doesn't work when the sender unit is connected, then it may be the sender unit at fault, which is not uncommon.
Author:  1976miniss [ Tue Jul 10, 2012 9:52 pm ]
Thanks, I'll give that a go :)
Author:  Convertible Mini [ Thu Jul 12, 2012 6:09 am ]
Post subject:  Temp Gauge.
And if your Printed Circuit is no Good come to me for a new one.
