It is currently Wed Jul 23, 2025 7:06 pm
 Post subject: orange dot clutch supply
PostPosted: Sat Jul 14, 2012 5:51 pm
I was looking at getting one from Karcraft but unfortunately they are out of stock for another 8 weeks.
So dose anyone else stock them?
PostPosted: Sat Jul 14, 2012 6:31 pm
Most mini suppliers can probably help you out....
Online is Aus :
http://www.minis.com.au/minis/catalog/product_info.php?cPath=34&products_id=568
http://www.minisport.com.au/prod308.htm
..... sure theres more ...
PostPosted: Sat Jul 14, 2012 9:19 pm
Minispares UK can probably supply and usually takes a week for delivery
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jul 17, 2012 9:50 pm
If I just get the orange dot pressure plate what clutch should I get?
Either a 8017, std replacment cooper S clutch?
or a AP racing heavie duty bonded cp2084-41 clutch?
PostPosted: Tue Jul 17, 2012 9:52 pm
The standard AP Cooper S etc one is fine for road cars, if racing I'd go the AP bonded and rivetted one.
PostPosted: Tue Jul 17, 2012 10:02 pm
Just to clarify it's for a 100+ bhp mini, daily driver that is driven hard.
What are the pros and cons to each clutch?
PostPosted: Tue Jul 17, 2012 10:08 pm
The bonded & rivetted (rally etc) one is less likely to fly to bits if you give it a hard time. However as there's (maybe, was long ago, can't remember now) no springy bits in between the facings it could be more abrupt on bite than the std rivetted one.
Probably not a problem to you and me. :P
[edit] an orange dot diaphragm is fine for road use if it's N/A. Twinky even. :wink:
[edited] for clarity
Last edited by drmini in aust on Tue Jul 17, 2012 10:26 pm, edited 2 times in total.
I'm using a grey dot with normal "cooper s" clutch plate
PostPosted: Wed Jul 18, 2012 6:45 pm
Thanks everyone, time to go order some bits :) .
