It is currently Wed Jul 23, 2025 7:13 pm
 Post subject: Extractors
PostPosted: Tue Jul 17, 2012 7:16 pm
Has any body got any tips on how to get my cooper s extractors out with the engine still in the car , Carbies are off , extractors are off , just can't get them out :evil:
I am putting in a set of freeflow maniflows
Mark
PostPosted: Tue Jul 17, 2012 7:17 pm
Online
Drop the remote off at the front, then undo the engine steady bar for more wiggle room?
Might help...
PostPosted: Tue Jul 17, 2012 7:22 pm
Yep done that Kev
About to remove R/H engine mount, R/H uni drive flange , grille , oil cooler , just to move the engine forward, :roll:
Mark
PostPosted: Tue Jul 17, 2012 7:36 pm
Are you talking about the original style Cooper. S extractors?
I thought they did come out with the engine in? Just need a bit of wiggling around :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jul 17, 2012 7:44 pm
Yes Michael , the original type ,just can't seem to get the bottom bend section up between the fire wall and the gear box , drive output
Mark
PostPosted: Tue Jul 17, 2012 7:51 pm
Online
Mark
Maybe that's why most of these I see s/h have been butchered or broken there.. :cry:
PostPosted: Tue Jul 17, 2012 7:56 pm
And I guess you don't want to scratch that nice shiney paint
Sorry many years since I have seen a standard set of S extractors
But they must go in and out as I remember fitting a set to a mini deluxe many years ago
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Jul 17, 2012 8:13 pm
Definately don't what to scratch it
I remember having to put them in the engine bay before putting the engine in
an then bolting it all together because the risk of scratching the hell out of the bulkhead and firewall was just to scarey for me to put it all in assembled
Mark
PostPosted: Tue Jul 17, 2012 8:16 pm
Are these the pressed steel ones were talking about?
Can't you simply drop them?? ie instead of pulling them up, push them down...
PostPosted: Tue Jul 17, 2012 8:20 pm
Hi Brett
Don't think I have the height
I have it up on stands , but I don't think they will go past the diff housing
Yes they are the pressed steel type
Mark
PostPosted: Tue Jul 17, 2012 8:56 pm
Good luck, I don't think it can be done. I couldn't get mine in with the engine sitting in a bare subframe.
Cheers, Ian
PostPosted: Tue Jul 17, 2012 9:05 pm
a jack??
 Post subject: Extractor Removal
PostPosted: Tue Jul 17, 2012 9:16 pm
The best way to remove the original extractors is to disconnect the Hardy Spicer Joint on the Drivers side. Then either,knock the studs out of the Drive Flange to push the shaft aside or alternatively ,drop the top ball joint to give you the extra room required.Maybe tie it up with string,to give some clearance. With the engine steady released,the Extractors should then come out using this space near the Uni Joint.It still requires some manouvering,but thats how I have been doing it for decades.
PostPosted: Wed Jul 18, 2012 8:02 pm
Got them out as per origmini advise
unbolted engine mounts and oil cooler and moved the engine forward
has any body else had trouble with centre branch flange fouling on the inlet manifold ?. not the pipe , but the flange and the weld , had to grind it back so the inlet could sit flush on the head , what a pain in the rectum
Mark
Users browsing this forum: drmini in aust and 100 guests
