my wipers and indicators wont work (problem solved)
https://www.ausmini.com/forums/viewtopic.php?f=2&t=77606
Author:  min-E [ Sun Jul 15, 2012 10:40 am ]
Post subject:  my wipers and indicators wont work (problem solved)
Ok they were working but now their not... I haven't changed anything they just stopped all of the sudden. Fuses are ok.
Any ideas people?
Author:  drmini in aust [ Sun Jul 15, 2012 3:04 pm ]
Pull the fuses, clean all the copper blades on the fuse holder, ditto all the wire spade lugs attached thereto.
Author:  woodwormm [ Tue Jul 17, 2012 9:19 am ]
well it appears you now have a dedicated drag car - straight lines, dry weather only :P
Author:  min-E [ Tue Jul 17, 2012 9:55 am ]
:lol:
Author:  Irish Yobbo [ Tue Jul 17, 2012 10:56 am ]
This used to happen to me, and it was a simple case of tightening the fuse box. Take the accessories fuse out, and push the holding tabs in a bit to tighten the clamping of the fuse. If anything is rusty or corroded, cean it up with a bit of fine sandpaper.
Author:  min-E [ Tue Jul 17, 2012 11:19 am ]
Cheers. I've been busy lately but hopefully today or tomorrow I will do this. I will let you know if It's the cause.
Cheers Pete.
Author:  Gadgets mini [ Tue Jul 17, 2012 4:57 pm ]
and prepare a suitable sacrifice for the Lucas God that he might smile favourably on your Mini and bring the letrics back to life :wink:
Author:  Convertible Mini [ Tue Jul 17, 2012 10:32 pm ]
Post subject:  Simple tool .
Try with a test lamp and see where the power stops before you start pulling things apart.
Author:  min-E [ Fri Jul 20, 2012 4:18 pm ]
Dirty connections. Thanks drmini :)
