Alternate Steering Column
https://www.ausmini.com/forums/viewtopic.php?f=2&t=77614
Author:  1275LS [ Sun Jul 15, 2012 7:21 pm ]
Post subject:  Alternate Steering Column
Has anyone here ever switched over a standard steering column for a modern adjustable one mounted in the dash? Something from a late model small car that is pretty compact? It would need some uni joints to work I expect.
I am tall and do the knee knocking thing when I get in..
Author:  woodwormm [ Sun Jul 15, 2012 7:58 pm ]
aparently different models had diff length columns... someone with knowledge will be along soon enough.
I too am tall and have moved my seats rearwards, and lowered my column, though now where I sit the column could be a tad longer...
Perhaps a diff length column would help¿?
Author:  thomas_hb [ Mon Jul 16, 2012 2:42 pm ]
Ideally, a column which allows the steering wheel to be pointing perpendicular to the floor - i.e. no rake on the dish of the wheel. But, that'll need a uni joint on the column itself I suspect.
Author:  phillb [ Mon Jul 16, 2012 5:19 pm ]
Post subject:  Re: Alternate Steering Column
Does your car have one of those little accessory drop bracket things fitted? If it does then might be worth trying without it first.
Author:  poeee [ Mon Jul 16, 2012 5:29 pm ]
I've thought of doing this. Make long trips more comfortable.
Author:  1275LS [ Mon Jul 16, 2012 7:57 pm ]
Hey phillb, thanks for the thought but no...... Still the original Leyland column etc in mine complete with rust 8)
Author:  Convertible Mini [ Mon Jul 16, 2012 7:57 pm ]
Post subject:  Adjustable steering angle.
When I was fitting my "different" steering column I could have done it with angle adjust lever too as that is how it was in the Donor car, but I found that altering the wheel angle blocks the speedo and gauges from view which I did not like.
Author:  1275LS [ Mon Jul 16, 2012 10:41 pm ]
Post subject:  Re: Adjustable steering angle.
Thanks Tony. I saw your build.. it looks good. I am not after power steer though. When you were looking were there many units that would fit or did you have to modify the unit to fit?
