It is currently Sun Jul 27, 2025 9:04 pm
PostPosted: Mon Jul 16, 2012 10:09 am
got these 1.5 roller rockers from mini sport u.k and got a get of spacers as well . the spacers dont fit properly on top or bottom , if on top hit on the rocker arm. wondering if anyone had any issues with them ?? as there are no instructions with them and should be a straight forward process
PostPosted: Mon Jul 16, 2012 2:41 pm
If they have 3 holes in them they go under the rocker posts (if required) to allow rocker adjustment.
PostPosted: Mon Jul 16, 2012 3:52 pm
so no problem tightening onto the alloy
PostPosted: Mon Jul 16, 2012 4:04 pm
The rocker posts are plated steel, not alloy.
You can fit hardened washers if they are narrow, note the flanged late head nuts are NFG- they foul the rockers.
One set I did recently I machined the flanges down to clear.
