Without a radius rod the arm would be able to move slightly fore and aft, other than that, all the suspension load on the front is pushing the arm down where the ball sits in it and due to how far out the actual ball joint is, i'd guess the pivot of the arm is taking about 3 - 4 times the actual suspension load so any soft of even hard rubber/plastic would collapse quickly.
kimini wrote:
It's the boobs and testosterone that make this place fun-ner
Jimmyinamini wrote:
