I am going to do a quick swap of engine.
The current engine is a A+ 1275,
std Rover electronic dizzy,
pre-engaged starter ,
std rover oil filled coil.
The replacement engine is a Morris 1100S 1275, with a
Nissan pulsar dizzy,
Gemini starter motor,
Bosch GT40 rt coil (the little compact style).
So what I want to know is will all the colour coded items be compatible with each others wiring?
I don't want to swap the parts from the Rover to the 1100S if I can help it just want to know if I unplug all the wiring swap the engines and plug the wires back on to the same + or - terminals will it all work properly
