It is currently Fri Aug 01, 2025 10:58 am
PostPosted: Wed Jul 25, 2012 7:58 am
Good morning all,
Have installed the wiring into the car but have the distributor in and I had to cut the wires to remove the ignitor from it(rubber grommet replaced)and had to cut the wires. I now have forgotten where they go so where does the RED and BLACK wire go to(I am assuming the coil but I am fuzzy on electrical stuff!!)
Nearly finished this pig so your help, as always, is welcomed. More to come WRT lights and the like.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed Jul 25, 2012 8:29 am
Both go onto the coil- red to <+> and black to <-> terminal.
PostPosted: Wed Jul 25, 2012 7:46 pm
Thanks Kev - I assumed this was the case but just making sure. Your advice is always welcomed and always prompt!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed Jul 25, 2012 8:08 pm
Just don't leave the ignition turned on and engine not running, as the module won't thank you. :cry:
Hint: don't wire the radio through the ignition switch...
