It is currently Tue Jul 29, 2025 3:52 pm
PostPosted: Wed Jul 18, 2012 7:46 pm
When the Left hand drive shaft is installed, there is still some load onto the Diff (This is not Good).
All bits slide freely.
The Question is!!!....Are there different length shafts?...or what else may I have done wrong??
Early gear box..Drum brakes...rubber uni's...
PostPosted: Wed Jul 18, 2012 11:10 pm
Drive shaft is longer on the drivers side, not sure if the shaft lengths vary depending on uni type though. :?
What do you mean by load on the diff?
PostPosted: Thu Jul 19, 2012 6:48 pm
With the drive shaft installed the spline is pushed completely in. Which applies pressure to the wheel bearing and the dif.
Users browsing this forum: No registered users and 116 guests
