Damaged output shafts?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=77736
Author:  68Rusty [ Mon Jul 23, 2012 10:01 pm ]
Post subject:  Damaged output shafts?
I have two old gearboxes both with left hand side output shafts looking like this?
Anybody come across this before, can't think what would cause it. Maybe somebody has had gas axe to the U bolts to remove but both where from different cars?
Author:  Rob1970 [ Mon Jul 23, 2012 10:36 pm ]
At a guess considering their both left hand side and would be spinning anti clockwise it could be from too much power for the casting or loose/over tight u bolt cracking out under load.
Just a wild guess.
Cheers Rob
Author:  drmini in aust [ Mon Jul 23, 2012 10:47 pm ]
Very common, caused by a worn out rubber U/J- the U-bolt on the other yoke (on the driveshaft) has come across and worn into it.
I have a selection like those here, also plenty of good ones if you need any.
Author:  68Rusty [ Tue Jul 24, 2012 7:57 am ]
Thanks guys, that makes sense Kevin.
I have a few to rummage through; I will see if I have an ok one.
Author:  mini_mad_matt [ Tue Jul 24, 2012 3:30 pm ]
If you don't have any that are better, just swap sides with them, so that driving forward would wear the other side (if it flogged out)
Author:  TheMiniMan [ Tue Jul 24, 2012 5:21 pm ]
i have plenty of them here if you`re stuck
& yes it`s very common that they flogg out after the uni-joint wears a bit
Author:  68Rusty [ Tue Jul 24, 2012 9:35 pm ]
I really appreciate this Ausmini community, thanks for the help 8)
