It is currently Thu Jul 31, 2025 3:53 pm
 Post subject: Bushes
PostPosted: Wed Jul 25, 2012 9:18 pm
Just a thought I had after reading Tuck3r's thread on nylothane bushes
has any body ever thought about reaming out the top front control arms to take a bush instead of the bearings , also the rear swing arms ?
just a thought , most other cars are running on rubber bushes
Mark
PostPosted: Wed Jul 25, 2012 9:28 pm
Tomboss Breweros
Without a radius rod the arm would be able to move slightly fore and aft, other than that, all the suspension load on the front is pushing the arm down where the ball sits in it and due to how far out the actual ball joint is, i'd guess the pivot of the arm is taking about 3 - 4 times the actual suspension load so any soft of even hard rubber/plastic would collapse quickly.
kimini wrote:
Jimmyinamini wrote:
