It is currently Tue Jul 29, 2025 6:11 pm
 Post subject: Breather
PostPosted: Wed Jul 25, 2012 4:43 pm
Hey guys,
I've been searching ausmini and also googled it, but havent found an answer that satisfies, hence raised another thread on it. :oops:
Do I need the breather at the back of the engine if i have one on the rocker cover? In otherwords, how many breathers do i need?
Its a 998, upgraded head, 1.5SU and extractors. If that makes a diff.
(I have found lots on where breathers should be vented, atmosphere or back to carbie and I have decided I will hose the breather from the rocker to the carbie)
Thanks as always.
 Post subject: Re: Breather
PostPosted: Wed Jul 25, 2012 4:48 pm
This space for rent
If the one on the back of the engine is a crimped pipe, that's an air inlet and not a breather. Leave that one open to atmosphere.
If it's a canister, plumb it and the rocker cover to the carb vacuum port.
On a 998 you don't need tons of breather capacity, if the rings are in good nick the rocker cover will probably be enough but it doesn't hurt to have more.
PostPosted: Wed Jul 25, 2012 11:47 pm
Ok, thanks for the quick reply!
There are two blank covers at the back of engine, but I do have a cover with a canister thingo in my spares pile.
I'll plumb the rocker breather to the carbie and leave it at that.
