mini Pedal assembly cooper s? https://www.ausmini.com/forums/viewtopic.php?f=2&t=77798 |
Author: | NG [ Fri Jul 27, 2012 9:37 am ] |
Post subject: | mini Pedal assembly cooper s? |
I dont care i just want to buy one to convert from rover set up back to previous set up. have been told it is Cooper S, wider 5/16" brake pedal.?? seems like a rover set up to me? |
Author: | CARTER_GT [ Fri Jul 27, 2012 9:40 am ] |
On phone so can't check link but both the cooper S and mini matic had the bigger brake pedal. |
Author: | adamstuart [ Fri Jul 27, 2012 10:10 am ] |
Not sure about the pedal being bigger, but it could be I was under the impression the brake arm was thicker, so it wouldn't bend under heavy braking. Matic's also got the same pedal box |
Author: | drmini in aust [ Fri Jul 27, 2012 10:15 am ] |
Matic and S pedals were just thicker, not bigger. S pedal sits higher than a Matic one though. But a Matic one works fine with S brakes (I run em). Matic got a throttle pedal with a bigger pad than all the others too. |
Author: | graham in aus [ Fri Jul 27, 2012 2:14 pm ] |
Are Pedal foot pads square or sort of 'diamond' square shaped? I think all the later pedals (non square) went to thicker material for pedal blade? |
Author: | adamstuart [ Fri Jul 27, 2012 2:30 pm ] |
Square pedals on the S/Matic pedal box |
