It is currently Sat Jul 26, 2025 11:29 am
PostPosted: Sat Jul 28, 2012 9:20 am
I am putting my engine back in after the gearbox repairs and am trying to put the driveshafts back into the diff sockets but they won't go in. The last time I pulled the engine out they slipped in as easy as could be. I've undone the ball joints on both sides. The hubs are hanging loose and the engine is sitting just above the engine mounts. I can get the left side to half sit in there, but can still see the ball bearings sitting out and I cant push it in any further.I have tried rotating it a bit to ensure the ball bearings are lined up with the grooves in the socket but it just wont go any further. I haven't even tried to get the drivers side one in yet.
Any tricks to this? What am I doing wrong? Is this a two person job? I am going bald ripping my hair out in frustration....
PostPosted: Sat Jul 28, 2012 9:27 am
ok,,, if you have swapped them (thew pots) from side to side accidently during the gearbox overhaul then maybe one is smaller than the other
there are a whole heap of after-market & reco Inner CVs on the market with different sizes
maybe pop the pot out & try it on the other axle???
if it fits then swap em both over
PostPosted: Sat Jul 28, 2012 9:29 am
Sorry Clive,,, maybe i should have said, --> If "I`ve" swapped pots over during the overhaul :-)
PostPosted: Sat Jul 28, 2012 10:11 am
He he he, I was just thinking "does Matt do house calls?". I will go have a look. It does sound rather technical tho. I better do some reading of the workshop manuals.
PostPosted: Sat Jul 28, 2012 10:20 am
Not too technical clovus
Basically there are two types of pot joints, big and small
They look almost the same, and unless you have one of each side by side it's hard to tell which one they are.
The pot joint isn't too hard to remove, you just hit it with a drift to knock it out. It has a circlip on it, so make sure that is all hunky dory before you put it back in.
Unless Matt has a better way to remove them?
You're so square
Baby I don't care
PostPosted: Sat Jul 28, 2012 10:47 am
Ok, I feel like a bit of a goose......
Before my first post I was getting frustrated. Having a break to post gave me a chance to think it through. So I lubed her up really well, changed the angle of the shaft and it just popped in when I gave it a bit of a push.
Far out! Anyways onto the ball joints. Not wanting to have a future contribution to the " what did i break" thread, what is the torque setting for the ball joints? I can't find it in my black workshop manual.
PostPosted: Sat Jul 28, 2012 10:50 am
Torque on the big balljoint (1-1/2") socket is 72lb/ft.
Users browsing this forum: No registered users and 115 guests
