It is currently Mon Jul 21, 2025 12:28 pm
 Post subject: Valvemaster fluid
PostPosted: Sat Jun 04, 2005 4:44 pm
I was told by someone that Valvemaster fluid accually damages the valves after time. Is this true? Could somebody sudgest an alternative?
 Post subject: search ausmini
PostPosted: Sat Jun 04, 2005 4:51 pm
Valvemaster and flashlube have been discussed here....do a search...I think the concensus is that Flashlube is good....valvemaster is something else :oops:
PostPosted: Sat Jun 04, 2005 4:55 pm
Flashlube is the way to go. As 9y said, do a search, there is alot of info on lead replacement additives.
PostPosted: Sat Jun 04, 2005 5:28 pm
Flashlube works out cheaper. 1mL = 1L of fuel, so 1L does 1,000L and costs around $16. That's peanuts. Extra 1.6c/L. And it works.
It won't crap your plugs etc up like Valvemaster does either.
Available from Repco, AutoPro, AutoOne etc. :wink:
ps. the cap on the 1L bottle is 7.5mL, so I use a capful for every 7 or 8L of fuel.
PostPosted: Sat Jun 04, 2005 5:50 pm
While we're on the subject, after converting for unleaded is it still a good idea to use flashlube every now and then or is there no need at all?
 Post subject: UCL
PostPosted: Sat Jun 04, 2005 5:53 pm
its an upper cylinder lubricant etc....it should benefit just about any four cycle engine....
