It is currently Mon Jul 21, 2025 1:39 pm
 Post subject: engine timing
PostPosted: Thu Jul 26, 2012 7:58 pm
hi all i have got my engine at top dead centre on cylinder one the timing mark on the flywheel lines up but i can get the engine to run it will wind and wind but wont carry through and run, ive got plenty of fuel and spark what could it be. do i have the dissy in the correct spot on the spindle?
PostPosted: Thu Jul 26, 2012 8:08 pm
You need to check that you are on top dead centre , compresion stroke not exhaust, take the rocker cover off and wind the motor over by hand to make sure , watch the rockers on number one. once you are on compresion stroke . take the distributor cap off and see were the rotor button is pointing,
this will be your starting point for number 1
PostPosted: Thu Jul 26, 2012 8:14 pm
im sure ive got it one the compression stroke the rotor button is pointing straight up at number 4 cylinder. I ve put the leads on in the order of 1342 in an anticlockwise direction from the rotor button
PostPosted: Thu Jul 26, 2012 8:21 pm
Is number 1 lead where the rotor button is pointing ?
PostPosted: Thu Jul 26, 2012 8:36 pm
yes
PostPosted: Thu Jul 26, 2012 8:47 pm
Turn the dizzy body clockwise a bit to advance it, most motors like static timing at around 10° BTDC.
PostPosted: Thu Jul 26, 2012 8:50 pm
My rotor points to number 1 cylinder at spark
PostPosted: Thu Jul 26, 2012 8:55 pm
Double check again the rockers are both loose on #4 when the rotor is pointing there.
ALL the workshop manuals for the last 50 years are WRONG in that they show one pic of the cam timing marks lined up dot to dot (= firing on #4 but they don't say this), then there's another pic showing the dizzy driveshaft in the right position for firing on #1.
They neglect to tell you that you have to turn the motor 1 TURN before fitting the dizzy driveshaft, to have this happen.
:wink:
PostPosted: Thu Jul 26, 2012 9:00 pm
sounds like its 180 deg out
PostPosted: Thu Jul 26, 2012 9:05 pm
Ok doc I will check that tommorrow. Thanks for your advice
PostPosted: Thu Jul 26, 2012 9:12 pm
Get No 1 at TDC on the compression stroke (remove No 1 plug , stick thumb in hole and feel for pressure).
Attach No 1 plug lead to the terminal that the rotor is pointing at. Count off the other plug leads from there.
Cheers, Ian
PostPosted: Sun Jul 29, 2012 9:12 pm
So did you get it going ?
PostPosted: Mon Jul 30, 2012 7:15 pm
Yea got it going. Now I've got a problem with the starter motor not disengaging
