Get a bundle of zip lock bags.
For everything that you pull off the engine including the fasteners (even if you plan to replace them) put it in a clearly labelled zip lock bag.
When you go to reassemble you will know exactly which bits go together and what fasteners go with them.
For the pushrods, I got a sheet of cardboard and punched holes in it to stick them in, labelled with numbers and with front of engine direction marked (i.e. towards water pump). For the cam followers, I stuck on some tape and numbered them before putting them in their bag. Same for the main cap bolts.
You get the idea.
Any parts to be replaced, I always inspect them and their mating parts and compare to the new ones.
If you are machining and reusing the crank, have it crack tested. Have it balanced with all of the clutch, harmonic balancer etc. attached.
Measure your bearing journals and bores before machining and after they come back.
Clean everything that will be reused as if you were going to eat off it, including the parts returning from the machine shop. I like to clean it before i put it in the bag. It takes longer but I know it will be clean and ready to go when I put it back together.
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
