It is currently Sat Jul 19, 2025 10:40 pm
 Post subject: Working out RPM?
PostPosted: Wed Aug 01, 2012 12:51 pm
Milatsmadmini
Does anyone have a good calculator application/powerpoint doc to work out rpm?
Here is the figures:
50.1hp @110km/h
3rd gear, 3.76 diff, 10" wheels...
There used to be a good one on the moke website, that has since disappeared...
PostPosted: Wed Aug 01, 2012 1:18 pm
I think Simon K mentioned one on here recently.
It would be nice if that damned dyno gave rpm on the X axis not KMH, wouldn't it. :lol:
[edit] your 3rd gear is 1.43:1, so with a 3.76 diff,
MPH/1000 = 14.7/1.43 = 10.28 MPH/1000 in 3rd.
or 16.65 KMH/1000.
so 110KMH = 6,600rpm approx.
PostPosted: Wed Aug 01, 2012 1:27 pm
This space for rent
I put this spreadsheet together ages ago, might be what you need...
[edit] Plugging your values into it (using Cooper 'S' gear ratios - 3rd being 1.357:1) gives 6130rpm in third at 110km/h.
[edit 2] Doc beat me, it's a little-wheeler Moke... then yes, 3rd is 1.430:1 but I get 6460 RPM at 110km/h.
PostPosted: Wed Aug 01, 2012 1:34 pm
Milatsmadmini
Thanks guys
PostPosted: Wed Aug 01, 2012 2:24 pm
I Ilke the one on the "Guessworks" site....
It has options for the majority of gearbox permutations ....
http://www.guess-works.com/Tech/ratio.htm
(I'm sure it used to have a kph option but seems only to be mph these days)
PostPosted: Wed Aug 01, 2012 3:35 pm
It's got an Oz rodchange box in it but with the std, non-S ratios. same ratios as Mini K.
