It is currently Thu Jul 24, 2025 5:47 am
 Post subject: rear subframe mounts
PostPosted: Thu Aug 02, 2012 1:11 pm
Hey guys,
I'm just in the process of stripping an Aussie clubman van for parts and have a query about the rear sub frame mounts.
Judging on the oxidation around the four trunnion (not sure if it's the right term?) I'd say they were aluminium? They certainly have a different footprint to them-where they meet the underside of the shell.
All four mounts are the same casting and having a larger foot print ad the sub frame at the rear has had the spot welding lands bent away for clearance.
Are these common place over in Australia?
Not long read the thread on the fabricated rear arms on here-interesting!
Glenn
If you idiot proof the world, only idiots there shall be!!!!!
PostPosted: Thu Aug 02, 2012 1:18 pm
Check the trunnions with a magnet...if cast bingo!
PostPosted: Thu Aug 02, 2012 2:04 pm
Yes they are alloy. Common yes. We had to save weight somewhere..... :lol:
No salt on the roads here, so why not. :wink:
PostPosted: Thu Aug 02, 2012 2:31 pm
My old 850 were made of steel/iron type of material definately not cast alloy. It had the steel/iron trumpets too.
PostPosted: Thu Aug 02, 2012 3:12 pm
Mods rock!
I'm not sure about the earlier cars but those of the 70's were alloy, however the Moke from about 79 on were steel.
PostPosted: Thu Aug 02, 2012 6:57 pm
I know my 78 clubman has alloy fittings
Can't remember the Cooper S but suspect they are steel?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Aug 03, 2012 8:01 am
cheers guys! :D
Users browsing this forum: No registered users and 112 guests
