It is currently Thu Jul 31, 2025 7:03 am
 Post subject: Foam for air filters
PostPosted: Sun Aug 05, 2012 4:28 pm
Is there a particular type of foam that people use for their ram flo air filters and where did you get it .
PostPosted: Sun Aug 05, 2012 4:30 pm
Does anyone have a different interior light to the standard mini one , what have you got ?
PostPosted: Sun Aug 05, 2012 4:31 pm
oops
PostPosted: Sun Aug 05, 2012 4:55 pm
i buy a big slab of "Finer filter" foam
lay the old bit ontop, mark it out, cut a round piece out & whack it in
easy-peasy
it`s pretty red too :-)
PostPosted: Sun Aug 05, 2012 5:05 pm
Thats good it will match the roof.
PostPosted: Sun Aug 05, 2012 6:20 pm
I've heard that the stock foam in ram flos is dodgy? Just switch straight to this finer filter foam? Is the replacement ram flo foam any good?
1977 LEYLAND MINI SUNSHINE 'S'
PostPosted: Sun Aug 05, 2012 8:01 pm
Finer Filter went bust years ago and got absorbed by Unifilter.
The standard Lynx Ramflo foam is rubbish, it is too restrictive and crumbles with age. And catches fire easy too.
Unifilter foam is the best IMO, it is pre-oiled, is polyurethane so doesn't rot, and has less flow restriction than the Lynx stuff.
P/nos:
LNX300 for round 300 series SU Ramflo filters
LNX400 from oval 400 series Weber Ramflo filters
Cost $9.50 ea approx.
Available online from Unifilter. Buy some filter oil, too.
http://www.uniflow.com.au/contents/en-us/d141.html
PostPosted: Sun Aug 05, 2012 8:21 pm
Hey Dr where did u buy the slab of funer filter ? $$$$$?
I need a slab just for the 7 port....
Cheers......you Rylestoning this yr?
Now with 2 extra ports!
PostPosted: Sun Aug 05, 2012 8:42 pm
Leigh it wasn't me, it was Matt... he must have an old slab 10 years old, unless Unifilter are selling Finer Filter foam (I've not checked the whole Unifilter site. There is no Finer Filter sita now AFAIK.
Just buy the LNX400 pre-cut ones off Unifilter, $9.50 ea, see my post ^^^
Nope no Rylestone this year, $$$ has been tight lately.
PostPosted: Sun Aug 05, 2012 8:50 pm
Sorry Kevin! I have found the unifilter ones to be a little short in places allowing gaps around the edge of the cage. That's why I was hoping to be cut me own.
They should book you as the support vehicle for the run!
Thanks.
PostPosted: Sun Aug 05, 2012 8:58 pm
Ring or email Unifilter I bet they will sell you a slab.
They are in Gosford now...
Users browsing this forum: Bing [Bot] and 92 guests
