Moke and Mini Compatibility (Parts) https://www.ausmini.com/forums/viewtopic.php?f=2&t=77932 |
Page 1 of 2 |
Author: | kiwiinwgtn [ Mon Aug 06, 2012 6:41 pm ] |
Post subject: | Moke and Mini Compatibility (Parts) |
What parts a specifically Moke. What I am trying to figure out what is unique to a Moke. other than the obvious eg gear boot, body, rear trailing arms Ta Kiwiinwgtn |
Author: | willy [ Mon Aug 06, 2012 6:54 pm ] |
Just about everything else that you've listed. ![]() ![]() Bumpers won't fit Oh wait, that's obvious. Um..... what did you have in mind??? |
Author: | adamstuart [ Mon Aug 06, 2012 6:54 pm ] |
Pedal box is different If you want bumpers, you need to weld on the mounts, or get one with mounts That's all I can think of |
Author: | AEG163job [ Mon Aug 06, 2012 6:58 pm ] |
Fuel tank Side light Rear lights Seats Floor mats Roll cage And you may have difficulty fitting a Moke grille to a Mini ![]() ![]() ![]() |
Author: | kiwiinwgtn [ Mon Aug 06, 2012 7:06 pm ] |
So are the motor, box are the same, brakes, suspension (other than rear arms) My investigations have found the following as special to the Moke. Body Rear Lights Rear Trailing Arms Pedal Box Gear Lever Boot Wiper Motor Bumpers Sump Guard Screen Seats Dash Have I missed anything Ta Bernard |
Author: | Morris 1100 [ Mon Aug 06, 2012 7:11 pm ] |
Diff ratio. Gearshift. Bonnet. ![]() |
Author: | bnicho [ Mon Aug 06, 2012 7:13 pm ] |
If you want to be completely correct the rear subframe has extra strengthening too. Also the rear suspension trumpets are van items. If you are doing a little-wheeler you can use more Mini parts. |
Author: | drmini in aust [ Mon Aug 06, 2012 7:13 pm ] |
Motor and boxes are much the same, except for diff ratio on the bigwheel ones. They mostly run a 4.13. For fitting 10" wheels to these most folks go for a 3.44 instead (if using a 1098 or 1275). |
Author: | Mokesta [ Mon Aug 06, 2012 7:46 pm ] |
Hand brake cables are a different length I think. Demister ducts Wiper assembly Wheels Sump guard Wheel arch trims Fuel level sender Floor mats Rear view mirror and wing mirrors Rod change to gear box links (shorter on moke) Exhaust (to go around rod change thing) Rear brake pressure limiting valve Choke and heater cables Dash switches M |
Author: | kiwiinwgtn [ Mon Aug 06, 2012 8:41 pm ] |
wow there is quite a difference then. more than I realised. |
Author: | mickmini [ Mon Aug 06, 2012 8:45 pm ] |
Per adamstuart - Moke front subframes have bits welded on to mount the bumpers, but 2 different kinds depending on the bumper style. Front subframes were also predrilled to fit the sumpguards. I only know this because i was looking at them at Mini King last week and John explained what all the bits were (thanks for another educational morning John) cheers michael |
Author: | CARTER_GT [ Mon Aug 06, 2012 9:12 pm ] |
I would say ask on mokes inc. but to them a moke has nothing what do ever in common with a mini... |
Author: | adamstuart [ Mon Aug 06, 2012 9:53 pm ] |
Kiwiington There isn't a load of difference, really. For the most part, you could reshell a mini into a moke. What everyone has listed is true, and most parts are obviously different - Lights, tank, switches and such. But if you aren't going for concourse, then you can fit pretty much everything. Handbrake cables wise, if you are using the longer moke arms, you can get moke cables from Karkraft. If you want to use mini trailing arms you will need to get custom cables made up, or buy 13" moke ones and shorten to suit. |
Author: | willy [ Mon Aug 06, 2012 9:54 pm ] |
CARTER_GT wrote: I would say ask on mokes inc. but to them a moke has nothing what do ever in common with a mini...
THIS! ![]() |
Author: | adamstuart [ Mon Aug 06, 2012 9:58 pm ] |
willy wrote: CARTER_GT wrote: I would say ask on mokes inc. but to them a moke has nothing what do ever in common with a mini... THIS! ![]() "But this one is a Morris MINI Moke" "Yeah, well, ours aren't mini's" |
