Help Tom with rookie carb questions
https://www.ausmini.com/forums/viewtopic.php?f=2&t=77933
Author:  tomtom [ Mon Aug 06, 2012 7:08 pm ]
Post subject:  Help Tom with rookie carb questions
Hi all, working on a spare carb that came with my mini. Got most of the way through dismantling it but the Plunger (I think that's what it's called) is stuck I to the dash pot cover. How should I try and get it out? Something tells me hitting it with a hammer is a bad idea. Here's a pic
Also what is this whiteish plastic thing? And the little black rubber over something in this pic too?
Thanks guys, just trying to learn a bit more about how my car works :)
Author:  drmini in aust [ Mon Aug 06, 2012 7:36 pm ]
That piston is corroded into the bell, it has so much corrosion in there it won't work properly even if you could get it apart (which I doubt).
They have very little clearance, they slide up and down, and seal vacuum with no sealing rings.
It is boogered- go find a better one. It's an HS4 carb, there are plenty about.
The white plastic tube out the side is a vac port, it goes to the crankcase breather on the engine.
Author:  Morris 1100 [ Mon Aug 06, 2012 7:41 pm ]
I would give the piston a soak in Penetrene or Yield and free it up.
If it is too corroded it may not be any good to use but it will be something to practice on.
Author:  mini_mad_matt [ Mon Aug 06, 2012 7:48 pm ]
The little black rubber is just plugging a vacuum port which can be used for distributors vacuum advance.
You can probably give the piston a tap from the top after soaking it as Morris 1100 suggested. If you have the piston dampener out you might have something you can slide down inside that you can tap on gently.
Author:  Morris 1100 [ Mon Aug 06, 2012 7:53 pm ]
Tap it inwards after applying some penetrating oil it will free up. You may have to then rotate it a bit to polish off the rough bits to get the piston back out again.
Author:  tomtom [ Mon Aug 06, 2012 9:23 pm ]
Thanks for the help guys, didn't realize it was a HS4 as I thought it had a HS2 on it at the moment but I didn't pay much attention.
I'll give it a go tomorrow afternoon.
What's the rules with sizes based on engine. I have an 1100, is there one I should stick to? Or is that a broad question? What about dual carbs? When do you and dont you run them?
Learning is the only true path to enlightenment 😊
Thanks, can't believe what people would do without the Internet!
Author:  sitnlo62 [ Mon Aug 06, 2012 10:08 pm ]
You could try heating it up with a hot air gun and using some WD40.
Author:  tomtom [ Tue Aug 07, 2012 10:11 pm ]
Yep, seems pretty siezed, I'm trying to soak it but I don't know how well it will move.
But we'll come back to my other questions:
Author:  drmini in aust [ Tue Aug 07, 2012 10:18 pm ]
An HS2 works (all 1098s had one) but an HS4 and manifold off a late 998 is worth a couple more HP.
Twin HS2s work well and look great, give more torque but are a bit harder to keep in tune.
Author:  tomtom [ Tue Aug 07, 2012 10:46 pm ]
AFAIK it was a 998 that they changed to 1098 (they share the same block, just different head yes?), I believe from memory it was a HS2 on there (the mini is not stored at my place cant' just walk out and check :cry: )
I might look into prowling ebay and the Mini Muster for hs4's then and report back if I have more carb q's. Thanks!
Author:  MrFail [ Wed Aug 08, 2012 5:54 am ]
Same block, different crank.
If it was only different head, they'd be the same capacity. :wink:
Author:  69k1100 [ Wed Aug 08, 2012 7:32 am ]
And different pistons.
