good distributor https://www.ausmini.com/forums/viewtopic.php?f=2&t=77959 |
Author: | TBOT70 [ Wed Aug 08, 2012 7:32 pm ] |
Post subject: | good distributor |
thinking of changing my standard dissy, what are everybody's recommendations?? engine is a 1275 cooper block, twin 1.25" carbs, and has electronic ignition, not sure what cam etc, does have 1.5:1 roller rockers however cheers guys |
Author: | drmini in aust [ Wed Aug 08, 2012 9:27 pm ] |
I like modified Pulsar dizzys, they are more reliable than electronicked Lucas ones. They don't seem to let the smoke out if you leave the ign on. Hitachi smoke = stronger magic than Lucas+Chinese module smoke. ![]() |
Author: | coopar [ Wed Aug 08, 2012 9:51 pm ] |
Look through simonbbc's range on ebay |
Author: | TBOT70 [ Thu Aug 09, 2012 5:39 am ] |
do i need vacuum advance or can i go without? |
Author: | drmini in aust [ Thu Aug 09, 2012 8:32 am ] |
TBOT70 wrote: do i need vacuum advance or can i go without?
Vac advance is just an economy device- at full throttle they do SFA. Most small euro performance engines of the 60s & 70s don't use them (eg. Cooper S, Alfa Romeo, Fiat, Lancia, etc). The smog Minis sold here from 1976-1978 didn't have any vac advance, either. You can't easily run it with a Weber or Dellorto carb, they have no suitable connection for it at the throttle butterfly. Racers remove it as it's just something to go wrong, and the breaker plate and timing is more stable without it. |
Author: | 850man [ Thu Aug 09, 2012 9:10 am ] |
http://www.performanceignition.com.au/s ... stributors |
Author: | slide [ Thu Aug 09, 2012 6:33 pm ] |
+1 for Scorchers |
Author: | TBOT70 [ Thu Aug 09, 2012 7:08 pm ] |
850man: just ask for scorcher ignition kit to suit a 1275 with electronic ignition?? |
Author: | 1275LS [ Fri Aug 10, 2012 8:53 pm ] |
coopar wrote: Look through simonbbc's range on ebay
+1 for these. |
Author: | 850man [ Fri Aug 10, 2012 9:17 pm ] |
TBOT70 wrote: 850man: just ask for scorcher ignition kit to suit a 1275 with electronic ignition??
Yes, they sell both points & elec types. Tell them what engine size & cam spec and they will make a new Bosh distributor with an advance curve to suit your engine. |
Author: | 1071 S [ Sat Aug 11, 2012 5:46 pm ] |
Vac advance is just an economy device.... Yep that's about it ... if you're happy to pay the equivalent of $2/l for fuel, you don't need one... Cheers, Ian |
Author: | The Ranger 89 [ Sat Aug 11, 2012 8:58 pm ] |
hey are the USB tunable 123 dizzys any good? i mean for just bolt it in, connect leads then get it prof tuned? |
Author: | gruhms [ Sat Aug 18, 2012 6:00 pm ] |
Any opinions on the Aldon yellow dizzy? My engine is a fairly similar spec to the OP, bored to 1310cc, twin 1.5" SU's, mild road cam 1.5:1 roller rockers etc. |
