Morris 850 "Fuse box" https://www.ausmini.com/forums/viewtopic.php?f=2&t=77986 |
Author: | cush [ Fri Aug 10, 2012 12:17 am ] |
Post subject: | Morris 850 "Fuse box" |
I've got two fuses and a shite load of wires coming and going from each.. What should be where? Anyone got some pictures? |
Author: | Harley [ Fri Aug 10, 2012 12:21 am ] |
I got a picture. ![]() ![]() |
Author: | MrFail [ Fri Aug 10, 2012 6:15 am ] |
cush wrote: I've got two fuses and a shite load of wires coming and going from each.. What should be where? Anyone got some pictures? There is some wiring diagrams on here somewhere if you do a quick search. ![]() Harley wrote: I got a picture.
![]() ![]() Haha, is that ur dog??? |
Author: | goodie [ Fri Aug 10, 2012 8:22 am ] |
MrFail wrote: ![]() Haha, is that ur dog???[/quote] It's to do with whats written on the bowl ![]() ![]() ![]() |
Author: | MINImal effort [ Fri Aug 10, 2012 10:33 pm ] |
Photo very apt ![]() ![]() Wiring diagrams (at least similar) can be found at : http://www.minimania.com/MM/Mini_Wiring_Diagrams_Now_On_Line_1362.htm eg check out the 850 one : http://www.minimania.com/images/wiring/PDFs/wiring15.pdf There is a basic colour coding set of rules (valid for all older minis) : BROWN comes from starter solenoid /Alternator/Generator and brings in the power to "Terminal 1" = Unfused always live. The other side (via fuse) Terminal 2 = Fused always live - and PURPLE wires. Terminal 3 = Unfused via Ignition Switch = Unfused switched - WHITE wires Terminal 4 = Fused via Ignition switch = Fused Switched = GREEN wires. ------ 1 <-> 2 -------- ------- 3 <-> 4 ------- |
